Abbey Bike Tools Decade Chain Tool
Article number: | 06-06-02 |
Availability: | In stock (5) |
During development and testing of this remarkable tool, over 10,000 chains were broken on a single tool and pin, which equals 3 chain installs per day for a decade! Because of that, this tool was given the name "Decade".
The tool’s beautifully machined aluminum handles are anodized in the signature Abbey green, and feature a white Abbey logo. The large handles ensure ease of use no matter what type of chain is being worked on. The main body of the tool and the lead screw are manufactured from cro-moly steel for durability. The lead screw and threaded body are treated with a low friction powder vapor deposition (PVD) coating that gives the tool an incredibly silky-smooth feel when in use. The pin itself is manufactured from a shock-rated tool steel for ultimate durability. In all likelihood, this freely-rotating pin will last as long as the tool itself, however the tool does include a spare pin housed it’s handle. These pins are cross compatible with both Shimano and Campagnolo pins.
This tool is compatible with 7-12 speed chains, including the new Campagnolo 12 and Shimano XTR M9100 chains. Housed in the handle with the spare pin is a backstop that threads into the backside of the tool; this backstop allows the tool to peen 11 and 12 speed Campagnolo chains to factory spec.
Material | Aluminum and Steel |
Compatibility | 7-12 Speed and Beyond |
Weight | 531g |
