Absolute Black Premium R9100/8000 Oval Road Chainrings
Article number: | 06-05-01 |
Absolute Black is a company that is undoubtedly at the forefront of the design and manufacture of oval chainrings.
Available in black or grey (for the big ring, small rings are available in black only) to best match your model of Shimano crank, these rings come in 53, 52, 50, 39, 36, and 34 tooth counts. Absolute black recommends the following combinations for best performance: 53/39, 52/36 and 50/34. They state that other combinations will work, but may result in slower shifting. As Shimano designed their cranks to have no more that a 16 tooth difference between rings, so combinations that have any more than this difference should be avoided. If only an oval small/inner ring is being installed, the Shimano factory chainring bolts can be used. If installing the oval outer/large ring long bolts are needed. These longer bolts are supplied with the Absolute Black bolt cover kits; these kits improve aesthetics by perfectly blending the oval rings with 9100/8000 series Shimano cranks (Kits not compatible with sub-compact chainrings).
Material | 7075 T6 Aluminum |
Compatibility | Dura-Ace 9100 series, Ultegra 8000 series, and 105 R7000 series 4-bolt, 110 BCD Cranksets. |
Weight | 34T (31g), 36T (37g), 38T (41g), 39T (42g), 50T (120g), 52T (137g), 53T(139g) |
