Bjōrn Glagol Carbon Seatpost
| Article number: | 011-05-06 |
Björn Glagol Carbon Seatpost is a lightweight performance seatpost designed for road and gravel riding where low weight, vibration damping, and secure saddle support are equally important. Using a tailored carbon layup for each length and diameter, Glagol balances stiffness, compliance, and durability without unnecessary material.
The wide clamp structure distributes load more evenly across the saddle rails to reduce stress concentrations while maintaining secure retention. Its reversible titanium hardware layout also simplifies adjustment access during setup and fit changes.
Available in both zero setback and 20 mm setback configurations, Glagol allows riders to optimize saddle position for aggressive race bikes, endurance setups, and gravel builds alike.
- Lightweight carbon seatpost for road and gravel applications
- Tailored carbon layup based on diameter and length
- Wide saddle clamp surface reduces rail stress
- Available in 0 mm and 20 mm setback options
- Compatible with 7 x 7 mm, 7 x 9 mm, and 7 x 10 mm saddle rails
- Reversible titanium hardware improves adjustment access
- Designed for performance, vibration damping, and long-term durability
Glagol is best suited for riders building a lightweight road or gravel bike where ride quality and saddle stability matter as much as reducing weight. The controlled carbon flex helps reduce road harshness while maintaining efficient power transfer during hard efforts and rough surfaces.
The availability of both setback and zero-setback versions also makes Glagol easier to match to modern aggressive fit positions as well as more traditional road setups.
Compatibility Notes
Glagol supports round and oversized carbon saddle rails, including 7 x 7 mm, 7 x 9 mm, and 7 x 10 mm rail standards. Always follow frame manufacturer insertion requirements and torque specifications during installation.
| Diameter | 27.2 mm | *30.9 mm | 31.6 mm | |||
| Offset | 0 / 20 mm | 20 mm | 0 / 20 mm | |||
| Weight | ~98 g | ~116 g | ~135 g | |||
| Minimum Insertion | 70 mm | |||||
| Max Insertion | 130 - 200 mm | |||||
| Saddle Rail Compatibility | 7 x 7 mm / 7 x 9 mm / 7 x 10 mm | |||||
| Rider Weight Limit | 120 kg / 260 lbs | |||||
| Material | Seatpost | Hardware | ||||
| Carbon | Gr5 Titanium PVC coated |
| * The 30.9 seatpost can be special ordered | ||||||
Cross-Linking Suggestions
Pair Glagol with the Björn Sedlo Saddle for a highly minimalist ultralight setup, or compare it with the Björn Divan Saddle and Björn Kort Saddle for more damped and supportive riding positions.
Complete the build with lightweight cockpit components and precision Risk Titanium hardware for a more cohesive performance-focused setup.
