Box Cusp 35mm Direct Mount Stem
Article number: | 10-04-05 |
Built to pair with their 35mm X Carbon Handlebar the Cusp Direct-Mount Stem allows riders to reduce weight and hardware while lowering the front end stack height. Direct mount stems improve stiffness and make handlebar installation a cinch. For those looking to upgrade to the benefits of a 35mm cockpit BOX has created a simple solution for every rider. Cold forged from 6061-T6 Aluminum this stem offers an excellent balance of strength to weight while outperforming similar stems with much higher prices. Finished with a mirror polished anodizing and subtle graphics this stem will match any build. The Cusp Direct-Mount stem, the perfect choice for any rider looking for a bit of style on a budget.
Material | Aluminum |
Bar Clamp Diameter | 35mm |
Weight | 50mm 173g |
