Carbon-Ti X-CarboRing EVO 9200 4-Arm Carbon Road Chainring
Article number: | 10-03-02 |
Carbon-Ti continues to impress with their high caliber engineering and design. The incredibly advanced X-CarboRing is now available in a newer 4-arm, 110 BCD configurations. This new chainring will work with Dura-Ace FC-9200 / 9100 / 9000 series, Ultegra FC-8100 / 8000 series, SRM Origin 4-arm series and Rotor Power Meter INSpider cranks. They are available in 54, 52, 50 tooth counts.
Weight is kept low using a mixture of carbon (inner body), AL7075-T6 aluminum (teeth), and titanium (shift pins). Using these varied materials, Carbon-Ti is able to achieve both a lightweight and highly functional ring, the aluminum and titanium parts aiding in shift quality and durability. The carbon fiber inner ring is bonded to a 7075 T6 aluminum tooth pattern, resulting in a unique way to drop grams on your next build, while simultaneously adding a touch of high-end class. By reducing weight from your drivetrain, the amount of energy required for a revolution of the crank is decreased, therefore optimizing pedal stroke and increasing power. Additionally equipped with special carbon fiber shift ramps, the Carbon-Ti X-Ring is designed to shift well under pressure, while remaining as lightweight as possible.
They are compatible with Shimano Dura-Ace 9200, Ultegra 8100, Campagnolo 12-speed groupsets, and all previous 11-speed groupsets.
IF YOU ARE LOOKING FOR THE INNER CHAINRING, PLEASE GO HERE TO ORDER THE 34T, 36T OR 40T. The inner ring works on all 4-bolt 110 BCD cranks
Material | Carbon (main body), Aluminum (teeth), Titanium (fixing pins) |
BCD | Shimano R9200 4-arm 110 BCD |
Drivetrain Compatibility | 12 speed road |
Weight | |
50 tooth | ~97g |
52 tooth | ~104g |
54 tooth | ~114g |
