Carbon-Ti X-CarboRing Carbon Road Chainring
Article number: | 10-03-01 |
The X-Ring from Carbon-Ti is an exquisite example of their design expertise in motion. Featuring a carbon fiber inner ring, bonded to a 7075 T6 aluminum tooth pattern, the X-Ring is a unique way to drop grams on your next build, while simultaneously adding a touch of high-end class. By reducing weight from your drivetrain, the amount of energy required for a revolution of the crank is decreased, therefore optimizing pedal stroke and increasing power. Additionally equipped with special carbon fiber shift ramps, the Carbon-Ti X-Ring is designed to shift well under pressure, while remaining as lightweight as possible.
Drivetrain Compatibility | 10 / 11 speed road |
Weight | |
53 tooth | ~85g |
39 tooth | ~35g |
52 tooth | ~78g |
36 tooth | ~32g |
50 tooth | ~73g |
34 tooth | ~27g |
