Carbon-Ti X-CarboRing X-AXS 5x110 BCD Carbon Road Chainrings
Article number: | 10-03-04 |
Carbon-Ti's line of SRAM AXS 12-speed compatible chainrings are thicker and stiffer than their non-AXS counterparts in order to keep up with the demands of SRAM's flagship electronic shifting system. These chainrings offer performance on par with SRAM's stock chainrings while shedding a good deal of weight, all in an incredibly attractive package. Carbon-Ti bonds their specially-profiled 7075 aluminum teeth with a high-gloss carbon center. The inner carbon surface of the larger rings is additionally shaped with ramps, and titanium shift pins are added for the best possible shift performance.
X-AXS 110 BCD 5-bolt chainrings are compatible with standard compact cranksets, allowing SRAM AXS 12-speed drivetrain compatibility with non-AXS cranks. These chainrings are designed to be used in specific combinations (50/37, 48/35, 46/33) for optimal shift performance and gear ratio transition. Other combinations are not recommended.
Carbon-Ti premium chainrings are 100% made in Italy.
Material | 7075 Aluminum, Carbon fiber, Titanium |
Drivetrain Compatibility | SRAM AXS 12-speed |
Crankset Compatibility | Standard compact 110 BCD (non-hidden bolt) |
BCD | 110 mm, 5-bolt |
Weight | |
50 tooth | 99g |
48 tooth | 92g |
46 tooth | 77g |
37 tooth | 37g |
35 tooth | 32g |
33 tooth | 31g |
