Carbon-Ti X-Fix Road Chainring Bolts
Article number: | 10-04-02 |
As an offshoot of exotic parts manufacturer, LLS Titanium, Carbon-Ti draws from a vast wealth of design and material science knowledge to bring the cycling community an impressive assortment of components for nearly every discipline.
The X-Fit chainring bolt series from Carbon-Ti is meticulously crafted to be the ideal bolt for nearly any available standard crank chainring interface. Each kit is designed to be universally compatible with any respective design. Each X-Fix mountain kit comes with enough bolts for any standard double OR triple design, making them universally compatible and simple to install. Each road kit features a set of 5 of the most common double-specific chainring bolts, taking the guesswork out of upgrading your build. Perfect for the cyclist looking for a dash of exotic Italian flair for their build, the X-Fix chainring bolt sets are a lightweight, minimalist option that won’t break the bank.
Material | 7075 Aluminum |
Weight | 8.5g |
Package Contents | |
Road | 5 double male, 5 double female, 4 10mm male |
XS MTB | 4 double male, 4 double female, 4 20mm male |
XS 20 MTB | 4 double male, 4 double female |
