Carbon-Ti X-Hub SP 6-bolt Rear Disc Hub
$410.00
Article number: 10-01-02
As an offshoot of exotic materials manufacturer LLS Titanium, Italy based Carbon-Ti draws from decades of material science and design experience to bring the cycling community an array of quality components. Since 2005, Carbon-Ti has produced uniquely handsome parts that make no compromises in either weight or performance.
The Straight Pull Disc X-hub is an excellent testament to Carbon-Ti’s attention to aesthetics and performance. Uniquely machined from 7075 T-6 aluminum, the Straight Pull X-Hub is both lightweight and resilient, two huge factors for the gram conscious rider who consistently finds themselves on terrain that tests the limits of their skills and componentry. Equipped with an ingenious tool less bearing preload adjuster, the X-Hub can be perfectly dialed in on the fly, and ensures that any adjustments stay where you want them. By simply turning the knurled endcap, any bearing micro adjustment is possible within seconds. Easy to overhaul and built to last, the X-Hub additionally utilizes the tried-and-true 4 pawl freehub body design featuring a quick-engaging 56 tooth ratchet ring, giving each rider the peace of mind knowing their components won’t fail in the middle of a long ride
The Carbon-Ti Straight Pull X-Hub is proudly designed and manufactured in Italy.
Material 7075 T6 Aluminum
Compatibility
Shimano / SRAM 10/11 speed,
Campagnolo, SRAM XD, SRAM XDR
Spacing 12 x 142mm
Weight 189g
