Carbon-Ti X-Hub SP Boost Front Disc Hub
Article number: | 10-01-01 |
As an offshoot of exotic materials manufacturer LLS Titanium, Italy based Carbon-Ti draws from decades of material science and design experience to bring the cycling community an array of quality components. Since 2005, Carbon-Ti has produced uniquely handsome parts that make no compromises in either weight or performance.
Carbon-Ti manufactures this hub from a solid block of Al7075-T6 aluminum, which is meticulously CNC machined to achieve an incredibly light weight while maintaining an impressive stiffness-to-weight ratio. The 17mm axle, also made of Al7075-T6 aluminum, has a variable wall thickness to keep the weight low while retaining strength in higher stress areas. This axle rides on two high-quality sealed bearings, with externally adjustable preload courtesy of Carbon-Ti's Bearing Preload System Tuning (BPS). This preload system, which consists of a machined dial and grub screw, makes hub adjustments quick and easy. These 110mm boost hubs come in at a very impressive 95 grams and are 100% made in Italy. With the combination of its light weight and robust build, Carbon-Ti's X-Hub SP Boost hubs should be at the top of the list for gram-conscious riders who push their components to the limit.
