ControlTech Cougar Carbon Road Handlebar
Article number: | 007-01-01 |
Controltech's Cougar carbon handlebar combines aerodynamics and comfort in a lightweight package. The strength-to-weight ratio of carbon fiber makes it ideal for the construction of the bars, achieving a strong and stable platform while remaining lightweight. Flared bar tops improve aerodynamics, while the triangular design of the drops improves comfort, control, and tactility.
The bars feature a 31.8mm clamp diameter, 125mm drop, 78mm reach, and are available in 40cm, 42cm, and 44cm widths. Drill-outs provide internal routing options for brake and shift housing as well as compatibility with Shimano's bar end Di2 junction box (EW-RS910). Weights range from 229 grams to 239 grams depending on bar width.
Stem Clamp Diameter | 31.8 mm |
Reach | 78 mm |
Drop | 125 mm |
Material | Carbon |
Compatibility | Internal Routing, Di2 Compatible |
Weight | 40cm 229g, 42cm 238g, 44cm 239g |
