ControlTech Newton Stem
$65.00
Article number: 007-03-03
ControlTech's Newton stem is an understated piece that performs its function to near perfection, leaving nothing wanting and nothing wasted. Middle weight, medium priced stems such as this can be found in countless iterations. The Newton Silver sets itself apart from the modern crowd with a classic look - an attractive, polished and clear-anodized surface adorned with minimalist printed graphics. The T6-tempered 7075 aluminum material promises superior strength, while both the steerer and handlebar clamp surfaces offer ample surface area for superior grip. The Newton is fitted with stainless steel hardware to inspire maximum confidence.
Material 7075 T6 aluminum
Hardware Stainless Steel
Rise +/- 5°
Stack 38 mm
Steerer Clamp 28.6 mm (1-1/8")
Handlebar Clamp 31.8 mm
Max Steerer Torque 10 Nm
Max Bar Torque 8 Nm
Weight (90 mm) 148g
Weight (100 mm) 157g
Weight (110 mm) 167g
