DT Swiss 180 EXP Road Front Hub 20h
$393.70
Article number: 11-04-05
With the latest generation of the 180 hub, the strengths of DT Swiss' top of the line hub have been further enhanced. The latest Ratchet EXP freehub system increases the bearing lifetime thanks to the increased bearing distance which also increases stiffness by a claimed 15%. Further machining has lightened the hub even more than the previous generation. The new version of the end caps simplifies the tool-free disassembly and makes maintenance easier. The hollow-machined ratchets transfers the energy invested directly into acceleration thanks to the 36 teeth. Combined with DT Swiss' SINC ceramic bearings, these hubs deliver a new level of performance.
Wheel Building
We recommend that wheels with DT Swiss hubs be built by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in rim and spoke selections. Please contact us directly or submit a form for a custom wheelbuild.
Weight 87 grams
Application Road
Brake Interface Rim Brake Only
Axle System 5mm Quick Release
Built-In Dimension 100mm
Number Of Holes 20
