DT Swiss 240 EXP Straight-Pull Centerlock Rear Hub
Article number: | 11-04-03 |
With the latest generation of the 240 hub, the strengths of DT Swiss' legendary hub have been further enhanced. The latest Ratchet EXP freehub system increases the bearing lifetime thanks to the increased bearing distance which also increases stiffness by a claimed 15%. Further machining has lightened the hub even more than the previous generation. The new version of the end caps simplifies the tool-free disassembly and makes maintenance easier. The hollow-machined ratchets transfers the energy invested directly into acceleration thanks to the 36 teeth.
Wheel Building
We recommend that wheels with DT Swiss hubs be built by an experienced wheelbuilder. We are happy to provide this service, and can provide helpful suggestions in rim and spoke selections. Please contact us directly or submit a form for a custom wheelbuild .
Weight | 191 grams |
Application | Road, Gravel, Cyclocross |
Brake Interface | Disc Only Centerlock |
Axle System | 12mm Thru Axle |
Built-In Dimension | 142mm |
Number Of Holes | 24, 28 |
