DT Swiss 350 J-Bend Disc Front Hub
$108.90
Article number: 11-05-02
Reliability meets simplicity, exactly according to this credo the 350 hub was developed. Designed for optimal function, the plugged construction allows easy maintenance without the need of tools.
The 350 hub line incorporates the key features of the famous DT 240 line at a more economical price. By slightly changing the manufacturing process and enlisting overseas facilities, DT is able to offer the same incredible performance for those on a budget. Utilizing common sized sealed cartridge bearings and a standard spoke hole drilling pattern, DT hubs can be serviced by any reputable shop or home mechanic with a few basic tools. For cyclists who depend on their gear lasting through the season and want peace of mind, or for those who demand the utmost of their equipment, a set of DT Swiss 350 hubs is a sound investment.
Weight 142 gr. 130 gr.
Axle Standard 15 x 110mm Boost 15 x 100
Bearing Sizes 6902 (2) 6902 (2)
Wheelbuilding Dimensions
Flange Diameter 44.0 mm
Center to Left Flange 27.4 mm
Center to Right Flange 40.0 mm
