DT Swiss 350 Centerlock Rear Hub
$223.90
Article number: 11-04-02
Availability: In stock (2)
DT Swiss changed the face of cycling when they introduced their DT 350 road hubs, a durable and extremely affordable alternative to the famous DT 240. The DT 350 is equipped with the venerable DT star ratchet system, and the same internals as their 240 counterparts. DT Swiss hubs are by far the easiest to overhaul, and require no specialty tools.
In response to popular demand, DT has taken a great leap forward for the mountain and road disc community by offering disc versions of the DT 350 hub set in nearly every standard.
Each DT 350 hub is backed by a full 2 year warranty against defects in materials and construction.
Road Disc Hubs
The DT Swiss 350 11 speed disc road hubs are not compatible with 11 speed mountain standards. Due to a difference in freehub design, as well as low spoke count, we recommend that any disc hub listed as road specific be utilized solely with disc road wheels. We do not recommend these hubs for mountain use.
Rear, Centerlock
Flange Diameter 46 mm
Center to Left Flange 33 mm
Center to Right Flange 20.2 mm
Weight 267 grams
Rear, 6 bolt
Flange Diameter, Left 58 mm
Flange Diamter, Right 52 mm
Center to Left Flange 33.6 mm
Center to Right Flange 20.3 mm
Weight 306 grams
