DT Swiss 350 Straight-Pull Centerlock Front Hub
$76.90
Article number: 11-04-04
DT Swiss' 350 series hubs offer exceptional performance and durability at an impressive price point.
Compared to a traditionally-spoked hub, these straight-pull hubs allow for increased spoke life by eliminating the spoke's j-bend, while reducing overall weight and increasing aesthetic appeal. While straight pull hubs limit spoke lacing to a single option, the spoke crossing and angles are optimized by DT Swiss for the best possible performance in real-world riding conditions.
We recommend bladed spokes be selected when building straight pull wheels as they are the easiest way to combat spoke windup. Check out the DT Spoke Calculator or contact us if you have questions on which parts to select for your next wheel build.
Weight 135 grams
Bearing Sizes 6902 (2)
Hub Shell Material aluminum
Axle Material aluminum
Axle Standard TA 15x100
TA 12 x 100
Brake Rotor Compatibility centerlock (6-bolt adapter included)
Recommended Use Gravel/CX, Mountain, Road Disc
Wheel Building Dimensions
Left Flange Diameter 38.5 mm
Right Flange Diameter 36.5 mm
Left Flange to Center 21.4 mm
Right Flange to Center 35.1 mm
Left Spoke Hole Offset 1.0 mm
Right Spoke Hole Offset 0.95 mm
