DT Swiss 350 Straight-Pull Centerlock Rear Hub
$223.90
This thru-axle, disc brake version of the DT 350 hub features straight pull flanges and a centerlock disc rotor mount (hubs include adapters for mounting 6-bolt rotors).  This straight-pull version of the famed 350 hub series has distinct advantages over traditional (J-bend) flange designs.; using straight-pull spokes allows excess material to be removed from the flanges, allowing lighter hub weights without sacrificing durability.  Another advantage is as the spoke enters and exits the flange in a straight line toward the rim, there is no excess stress put on the hub flanges or spokes, leading to increased durability.  The advantages this straight pull design, along with the tried-and-true DT Star Ratchet freehub mechanism and the overall reliability, durability, and serviceability of DT Swiss hubs makes the value of this high-performance hub undeniable.
Ordering
The 350 Centerlock platform features maximum adaptability between different axle standards and freehub body types, making it acceptable for use in multiple applications.  When ordering, please consider proper spoke hole drilling, axle type, and cassette compatibility.  We recommend bladed spokes be selected when building straight pull wheels as they are the easiest way to combat spoke windup.  Check out the DT Spoke Calculator or contact us if you have questions on which parts to select for your next wheel build.
Bearing Sizes 6902 x 2 (hubshell), 6802 x 2 (freehub body)
Available Drillings 24 hole
28 hole
Axle Standard TA 12x142
Weight (24 Hole, 12 x 142 Thru Axle) 227 grams
Weight (28 Hole, 12 x 142 Thru Axle) 227 grams
Wheel Building Dimensions
Drive side flange diameter 45.5 mm
Non drive side flange diameter 39 mm
Drive side Center to Flange 17.9 mm
Non drive Center to Flange 33.3 mm
Drive side Spoke Hole Offset 0 mm
Non drive Spoke Hole Offset 0.866 mm
