DT Swiss 350 Straight-Pull Road Front Hub 24h
$76.90
Article number: 11-06-05
The DT 350 is an excellent choice for budget-minded cyclists. In order to keep prices low, DT Swiss has simplified their manufacturing by making these hubs available in limited spoke counts; these straight pull versions are only available in 24 front, 28 rear counts. While that may limit rim options somewhat, a 24/28 spoke wheelset will provide excellent durability and long life for a wide range of rider weights and riding conditions.
The highly regarded reputation of DT Swiss hubs within the cycling market makes the purchase of a DT hub set a very safe investment indeed. The hubs are easily serviced and use common bearing sizes. All hubs are covered under a 2-year warranty against defects in materials and production.
Weight, Straight Pull 108 grams
264 grams
Bearing Sizes 6902 (2), 6802 (2)
Axle Diameter 15 mm
Available Hole Count 24, 28 hole
Recommended Use Road
