DT Swiss EXP 54t Ratchet Kit
$122.00
Article number: 11-06-01
Availability: In stock (4)
The new DT Swiss Ratchet EXP hub has been designed to be lighter, stiffer, and easier to maintain.
This 54 tooth upgrade kit makes for even faster engagement than the standard 36 tooth ratchet, which is perfect for mountain bikers or gravel riders trying to clear technical obstacles.
Having the fastest engagement possible can make the difference of keeping your balance and momentum or having to put a foot down and loosing time on your rivals or having to try again.
The DT Swiss EXP 54 tooth ratchet kit is compatible with all EXP freehub bodies.
Here's a video by DT Swiss explaining the process. We recommend taking your hub to a good shop that has the right tools for the job.
