Easton Pinline Foam Handlebar Tape
Article number: | 05-04-01 |
Easton's Pinline handlebar tape is manufactured from durable, non-toxic EVA foam and is offered in eight vibrant colors to match the colorway on just about any bicycle. The texture of this tape is soft and smooth, with a medium thickness for a perfect balance of comfort and security. The tape is embossed with Easton's Pinline logo, and includes standard plastic bar end plugs. The rolls are generous enough in length that wrapping thicker or wider handlebars will not be a problem.
Weight, Tape (2 rolls) | 54 grams |
Weight, Plugs | 6 grams |
Thickness | 2.3 mm |
Roll Length | 200 cm |
Material | EVA foam |
