ENVE 4.5 Carbon Clincher Rim
Article number: | 15-04-03 |
Introducing the ENVE SMART 4.5 road rims. Marginally heavier than the venerable SMART 3.4, the SMART 4.5 is the ideal carbon road rim for those looking for optimal aerodynamic characteristics over a wide range of conditions and terrain. Similar to other SMART rims, the SMART 4.5 is an asymmetrical rim design with separate profiles for front and rear wheels. Each front rim utilizes a slightly wider and shallower profile than the rear, which through comprehensive research has been found to minimize potential drag at a variety of angles.
Intended for use on nearly every kind of road terrain, the ENVE SMART 4.5 rims are designed to be extremely predictable in heavy crosswinds, and feature a molded texture braking surface to ensure ideal handling and braking characteristics. Utilizing the same tried-and-true molded spoke hole technology used in previous ENVE rims, the SMART 4.5 rims prove to be extremely durable and exceedingly laterally stiff.
Wheel Building
ENVE Rim Comparison
The following table compares ENVE's rim brake models for a quick and easy analysis. For more information follow the link to our product specific page for the rim or contact us to get in touch with one of our professional wheel-builders.
Model | Depth(mm) F/R | Width(mm) Ext | Width(mm) Int | Weight(g) F/R |
2.2 Tubular | 25 / 25 | 27 / 27 | N/A | 281 / 281 |
2.2 Clincher Tubeless | 25 / 25 | 27 / 27 | 18.5 / 18.5 | 420 / 420 |
3.4 Tubular | 35 / 45 | 26 / 24 | N/A | 377 / 397 |
3.4 Clincher | 35 / 45 | 26 / 24 | 18.5 / 16.5 | 458 / 464 |
4.5 Tubular | 48 / 56 | 27 / 25.5 | N/A | 370 / 400 |
4.5 Clincher | 48 / 56 | 27 / 25.5 | 18.5 / 17 | 475 / 489 |
7.8 Tubular | 71 / 80 | 29 / 27.5 | N/A | 436 / 468 |
7.8 Clincher Tubeless | 71 / 80 | 29 / 27.5 | 19 / 19 | 541 / 578 |
Weight (front/rear) | 475 / 489 grams |
External Width (front/rear) | 27.0 / 25.5 mm |
Internal Width (front/rear) | 18.5 / 17.0 mm |
Depth (front/rear) | 48 / 56 mm |
ERD (front/rear) | 563 / 545 mm |
Tire Compatibility | ISO 622 Road Tubeless |
Recommended Tire Width | 25 mm |
Material | Carbon Fiber |
Finish | UD Matte |
Brake Compatibility | Rim Brake Only |
Included Accessories | Enve 4.5 Road Tubeless Kit Enve 45mm Silca Valve Extenders (non-Tubeless) Enve Brass Internal Spoke Nipples |
