ENVE 5.6 Carbon Clincher Rim
Article number: | 15-04-02 |
With the SES 5.6 series you are not only getting a faster rim, but also one that is more stable in harsh wind conditions. The SES 5.6 rims feature a depth of 54mm for the front and 63mm for the rear and have been refined for the optimal combination of strength, stiffness, and weight for it’s intended applications: road racing and triathlons.
While at the top-of-the-class when it comes to speed and stability, these rims also feature Enve’s latest full carbon braking track. Enve has been able to set new standards in regards to carbon rim braking; this latest iteration features nearly equal wet and dry performance and a 30% reduction in lever force required for the same stopping power as the previous generation.
These rims include a tubeless kit consisting of tape and tubeless valves, just add a tubeless tire and sealant and you’re ready to go. In addition to the tubeless kit, these rims come with Enve black compound brake pads, and 45mm valve extenders.
Wheel Building
Weight (front/rear) | 494 / 517 grams |
External Width (front/rear) | 29.0 / 28.0 mm |
Internal Width (front/rear) | 20.0 / 19.0 mm |
Depth (front/rear) | 54 / 63 mm |
ERD (front/rear) | 548 / 532 mm |
Hole Count (front/rear) | 20 / 24 |
Tire Compatibility | ISO 622 Road Tubeless |
Recommended Tire Width | 25 mm |
Material | Carbon Fiber |
Finish | UD Matte |
Brake Compatibility | Rim Brake Only |
Included Accessories | Enve 4.5 Road Tubeless Kit Enve 45mm Silca Valve Extenders (non-Tubeless) Enve Brass Internal Spoke Nipples |
