ENVE 7.8 Carbon Clincher Rim
$975.00
Article number: 15-04-02
Availability: In stock (1)
In an attempt to create the ideal aerodynamic road race and triathlon clincher wheelset, Enve Composites has created the SES 7.8 rimset.
Designed to seamlessly integrate with aerodynamic framesets, and ideally paired with larger 25c tires, the SES 7.8 is touted by Enve as their finest aerodynamic rim option for race day roadies, and die-hard triathletes. Utilizing Enve’s venerable asymmetric rim profile, the SES 7.8 features a 71mm x 27mm front rim, coupled with an 80mm x 27.5mm rear rim, producing exceptional results on both flat, and hilly terrain. Additionally equipped with Enve’s redesigned brake track, the SES 7.8 boasts impressive increases to stopping power in both dry and wet conditions, while simultaneously being 100% tubeless compatible. Like all Enve rims, the 7.8 features proprietary molded spoke holes, resulting in a drastic increase in wheel strength.
All Enve rims are proudly manufactured in Ogden, Utah, U.S.A.
Wheel Building
ENVE Rim Comparison
The following table compares ENVE's rim brake models for a quick and easy analysis.
Model Depth (mm) Front/Rear Width (mm) External Width (mm) Internal Weight (g) Front/Rear
2.2 Tubular 25 / 25 27 / 27 N/A 281 / 281
2.2 Clincher Tubeless 25 / 25 27 / 27 18.5 / 18.5 420 / 420
3.4 Tubular 35 / 45 26 / 24 N/A 377 / 397
3.4 Clincher 35 / 45 26 / 24 18.5 / 16.5 458 / 464
4.5 Tubular 48 / 56 27 / 25.5 N/A 370 / 400
4.5 Clincher 48 / 56 27 / 25.5 18.5 / 17 475 / 489
7.8 Tubular 71 / 80 29 / 27.5 N/A 436 / 468
7.8 Clincher Tubeless 71 / 80 29 / 27.5 19 / 19 541 / 578
  Front - 71 mm Rear - 78 mm
Weight ~585 grams ~620 grams
External Width 29.0 mm 27.5 mm
Internal Width 19.0 mm 19.0 mm
Depth 71.0 mm 78.0 mm
E.R.D. (Effective Rim Diameter) 516 mm 504 mm
Recommended Tire Width 25 mm
Material Carbon Fiber
Brake Compatibility Rim Brake Only
Included Accessories ENVE Tubeless Kit / Internal Brass Nipples
