ENVE CX Carbon Tubular Rim 28h
Article number: | 15-04-01 |
For racers and riders looking to take advantage of the benefits of glue-on tubular tires (lighter tires and rims, lower rolling resistance/more supple tires, and the ability to safely run lower pressures to name a few), Enve introduces their CX Tubular rim. Enve designed their CX tubular disc rim with cyclocross racers looking for the ultimate in lightness, stiffness, and durability in mind. This disc specific carbon fiber rim has a tire bed that has been developed for use with 33mm tires and can withstand frequent tire installations and removals. This refined tire bed also reduces the instance of pinch flats. The Enve CX rim is 28mm wide and 31mm deep and is disc brake specific (it does not feature a brake track and cannot be used with rim brakes). Developing a rim for disc brake specific use enabled the engineering team to escape the design constraints of rim brake rims. This resulted in a substantially lighter and more compliant rim, without sacrificing strength or impact resistance. The Enve CX tubular rims come in a 28 hole count only, which maintains the optimal degree of stiffness and strength needed for the frequent accelerations and decelerations that define cyclocross racing. Enve CX cyclocross tubular rims are manufactured in the USA and are sold individually.
Wheel Building
Weight | 285 grams |
External Width | 28 mm |
Depth | 31 mm |
ERD | 596 mm |
Tire Compatibility | 28" Tubular |
Recommended Tire Width | 33 mm |
Material | Carbon Fiber |
Finish | UD Matte |
Brake Compatibility | Disc Brake Only |
Included Accessories | Enve Internal Brass Spoke Nipples |
