ENVE Carbon Gravel Handlebar
Article number: | 19-01-00 |
Availability: | In stock (3) |
To address the rise in popularity of gravel and adventure road cycling, ENVE has drawn from their extensive experience in the design and manufacturing of top tier carbon road and mountain components to proudly introduce their “road fast, mountain tough” G Series. Instead of simply adding a flare to the drops, the G Series bars feature a compound bend in which the drop flattens out as the bend progresses. The attention to detail found in the drop shape is exemplary of the overall focus on the bar’s ergonomic shaping. Only the clamping zones of the bars are round, leaving the rest of the bar ergonomically shaped to maximize hand comfort. ENVE's expertise in carbon laminate has allowed them to refine and tune the G Series bars specifically for gravel riding. The laminate has been refined for ideal vibration absorption while also providing the perfect amount of dampening flex in order to reduce fatigue while increasing control and confidence over tough terrain. To take it a step further, each bar size has a specifically tuned laminate, ensuring the ride quality is matched for both larger and smaller cyclists. Taking cues from their mountain bar designs, ENVE has made these bars wide for increased control and comfort. The G Series ENVE gravel bar is available in 4 widths, and feature a 120 mm drop, an 80 mm reach, and a 31.8 mm clamp diameter. Other features include a UD matte black finish with grey logos, textured clamping zones, and provisions for internally routing Di2 cables (including the newer Shimano bar end Di2 junction box).
Shipping ENVE Internationally
We no longer ship ENVE products outside of the United States. We apologize if this inconveniences you.
Width(C-C) at Hoods | 42 cm | 44 cm | 46 cm | 48 cm |
Width(C-C) at Drops | 54 cm | 56 cm | 58 cm | 60 cm |
Weight | ~248g | ~255g | ~265g | ~279g |
Reach | 80 mm | |||
Drop | 120 mm | |||
Internal Di2 routing | Yes | |||
Steerer Clamp Diameter | 1-1/8" or 1.125" | |||
Material | Carbon | |||
Clamp Area | 48 mm | |||
Torque Specs | Faceplate | Shift / Brake Clamp | ||
5.5Nm | 6 - 8Nm |
