ENVE Internal Brass Spoke Nipple
$0.52
Article number: Spokes
Availability: In stock (1322)
These replacement Enve spoke nipples are the same as those equipped in their full line of carbon wheels. These 10mm long nipples are manufactured from brass; a superior material for this application due to its corrosion resistance and low thread friction. The nipples are modified with a self-locking thread for extra security and trouble-free wheel builds. A 3.2mm internal spoke nipple tool is required for installation and adjustment. Whether you need to replace a single nipple, or upgrade an older wheelset with aluminum nipples, this is the spoke nipple you will need; this nipple is compatible with all past and present Enve rim models, as well as most other internal-nipple carbon rims.
Enve nipples are sold individually.
Weight 0.8 grams each
Thread 2.2mm x 56tpi [fits standard 14g (2.0mm) spokes]
Material Brass
Tool Fitting 3.2mm square, internal
