ENVE M730 Carbon Mountain Rim
$975.00
The M730 is designed around 2.3”-2.5” tires and 130mm-180mm suspension travel. Enve found that 32 spokes was the optimal count, needed to survive repeated technical descents at high speed. All M7 series rims share a 100% unidirectional carbon pedigree, however each has a specific laminate to ensure the desired impact resistance, stiffness, and compliance for the given application.
The M730 features Enve’s protective rim strip technology, a rim strip made from specially formulated material that acts as an extremely durable bumper between the carbon fiber of the rim and nasty trail obstacles. This technology results in near-elimination of “pinch” or “snakebite” style flats. Not only does this technology help prevent flats, but in doing so, also minimizes the chance of rim damage. Along with these benefits, the system allows riders to run lower tire pressures (improving traction and rolling resistance), the option to rider lighter weight tires, improved tubeless performance, elimination of the need for tubeless tape, and an independent tubeless seal that can allow air pressure integrity even when the rim is damaged.
Enve’s M730 is available in both 27.5”/650B (530 grams) and 29” (571 grams) versions, with a 32 hole count for either. The rims are backed by a “5 year no hassle warranty” from ENVE.
Wheel Building
Weight (27.5"/650B) 530 grams
Weight (29") 571 grams
External Width 38.0 mm
Internal Width 30.0mm
Depth 27.0 mm
ERD (27.5"/650B) 559 mm
ERD (29") 599 mm
Tire Compatibility Tubeless
Recommended Tire Width 2.3-2.5"
Material Carbon Fiber
Finish UD Matte
Brake Compatibility Disc Brake Only
Included Accessories Enve tubeless kit, Enve internal brass spoke nipples
