ENVE Titanium Skewers
Article number: | 18-03-01 |
Availability: | In stock (3) |
As a manufacturer known for continually demonstrating a dedication to innovation, Enve presents new products at regular intervals, but also spends time rethinking existing products. Having recently partnered with Mavic, it was only a matter of time until we started seeing obvious crossover products from Enve. These new titanium skewers sets are a brilliant rebranding of Mavic's excellent time-tested skewer design, with super-positive steel internal cams mated to gorgeous, yet understated composite levers. As a truly premium product, these Enve skewer sets feature an excellent balance of low weight, reliable function, and long-term durability.
Though designed to compliment a pair of Enve rims, these skewers are an excellent aftermarket option even if you haven't yet had the chance to upgrade to Enve wheels. The skewers are available in two options to fit all road, cyclocross, and gravel bikes. Generally, rim brake bikes are manufactured with 100/130 mm width dropouts, while disc-brake equipped quick-release frames use 100/135 dropouts.
Weight per Pair (100/130) | 90 grams |
Weight per Pair (100/135) | 91 grams |
Axle Material | Titanium |
Lever/Nut Material | Composite/Aluminum |
Recommended Use | Road |
Cam Travel | 1.9 mm |
Maximum Dropout Thickness (front/rear) | 7.5/9.0 mm |
