Feedback Sports Omnium Portable Trainer
$399.99
Article number: 33-01-01
The Omnium's versatility is matched only by its ease of use, enabling its usefulness across a variety of cycling disciplines and scenarios. Setup is quick and easy, and requires no tools at all. The fork mount includes adapters for maximum versatility, compatible with quick release, 12 and 15mm thru bolt, and boost axle standards. The Omnium's adjustable frame design accommodates a wide range of wheel diameters and tire sizes; whether you're riding road, mountain, or cyclocross (or all three), this is the trainer for you. The rear wheel rollers include an Internal Progressive Resistance unit to allow for an incredibly wide range of efforts for such a small package. When not in use, the Omnium folds down to just 26" in length; and at a mere 13.8 pounds, lifting it won't require a second thought. If this weren't enough, Feedback includes a heavy duty tote bag for convenient transportation and storage.
As with all Feedback products, the Omnium is impeccably designed and finished with high attention to detail, featuring lightweight, high strength aluminum construction. The Omnium is covered by a 3-year warranty.
Weight 13.8 lbs (6.21 kg)
Folded Dimensions 25.75″ x 7.25″ x 8″ (66 cm x 18 cm x 20 cm)
Compatible Bicycles Road, Triathlon, Mountain, Gravel, Cyclocross
Fork/Axle Compatibility 9x100 QR; 12×100, 15×100 & 15×110 (boost) thru axles
Wheel/Tire Size Compatibility 600c – 700c, 26″-29″
Adjustable Wheel Base Range 840mm to 1200mm
Rider weight limit 225 lbs
