FSA K-Wing Compact Carbon Handlebar
Article number: | FitWorks |
This compact bar includes several particular features that set it apart from traditional drop bars. The first and most noticeable is the raised flat top; with a slight back sweep, aerodynamic profile, and ergonomic design. This raised portion offers a more relaxed position and provides ample space to rest your hands. The bar tops also feature slight cut-out like shaping on either end, providing a nice perch for the palms when riding positioned at the widest part of the bar tops. The compact drops allow easy and fast swapping from the bar tops to the drops. In addition, the compact 125mm drop and 80mm reach allows riders to maintain hand position regardless of which lever or button they need to access, eliminating awkward re-positioning. Enlarged internal cable routing slots allow easy routing of both brake and derailleur cables and also work with electronic shift systems.
Made from a unidirectional carbon fiber and kevlar composite mixture, the K-Wing offers stiffness, durability, and vibration damping. All clamping zones of the bar are textured to ensure a slip-free interface.
Stem Clamp Diameter | 31.8 mm |
Reach | 80 mm |
Drop | 125 mm |
Back Sweep | 2° |
Material | UD Carbon Fiber, Kevlar |
Finish | Carbon Gloss |
Length | Weight |
38 cm | 231 grams |
40 cm | 237 grams |
42 cm | 248 grams |
44 cm | 254 grams |
