Lightning Carbon Road Crankset
Article number: | 09-02-01 |
Often copied, replicated and licensed, Lightning's revolutionary crank is now available with a number of bottom bracket options to adapt to most frame standards. The crank features carbon arms with an aluminum spider, joined in the center by a Hirst Joint (ala Campagnolo). Lightning claims a q-factor of 158mm. Available in a number of lengths, as a standard 5-bolt 130BCD or compact 110BCD, a 4-bolt 110BCD (Shimano 9000/9100), Clydesdale, and with ceramic bearing upgrades. Additionally, compatible with Power2Max power meter.
With this latest version, Lightning has managed to shave around 50 grams off the previous crankset while still maintaining the same performance characteristics.
Ordering
Lightning cranks are modular. Order the crank length, spider and bottom bracket that you need. We will install the spider arm onto the crank for you. If you're ordering a spare spider you'll need a spider tool. All Lightning Spiders are compatible with both Road and Mountain Lightning Cranks. If you desire a non traditional chainring setup, nearly any configuration can be achieved. If the option is not available here, please contact us and we will be happy to order it for you.
Special Orders
If you'd like to order Clydesdale cranks or ceramic bottom brackets contact us.
