Lightning Direct Mount Crank Spiders
Article number: | 09-02-02 |
In an effort make their cranks as universal as possible Lightning has created an interchangeable spider system that allows for quick installation of a wide assortment of chainring options. Available in compact and standard configurations these spiders afford the user the ability to tailor their crank to their intended application. Machined from fatigue resistant 2024-T4 Aluminum and then anodized a slick silky black these spiders will pair with any modern chainring system. Many spider configurations are available, if you do not see the one you are looking for contact us for availability.
Compatibility | Weight |
5-bolt - 130 BCD | 46 grams |
5-bolt - 110 BCD | 39 grams |
4-bolt - 110 BCD(Shimano 9000/9100) | 41 grams |
