Recon 11 Speed Aluminum Road Cassette
Recon aluminum cassettes feature eleven cogs machined from a single piece of aluminum. This offers the lightest weight performance possible. Several colorful options as well as multiple surface coatings give a unique appearance as well as increased cassette life.
Precaution for Alloy Cassette:
- Shifting performance and durability are greatly affected by the state of the chain and cables. The shifting needs to be adjusted perfectly to ensure best performance.
- Best shifting performance is achieved with Shimano or KMC 11s high-end chains.
- Please give alloy cassette gentle and average shifting. Make sure the chain is in proper position when applying power. If chain is not in correct position, the teeth can easily become damaged or broken and cause chain skip
