THM Clavicula M3 MTB Crank Arms w/o Spider
Article number: | 26-02-00 |
Weight |
~340g (For Crankarms and Spindle) Total Weight: 410g (with 34T Boost 12s) |
Spider options: |
120/80 bcd double spider ~48g |
Mounting |
BSA, BB30, Pressfit30, adaption for Shimano Pressfit, BBright™ |
Q-Factor |
167 mm |
Chainline |
49 mm - single 49.5 mm - double 50 mm - triple 52 mm - Boost |
Inner width of the cranks |
137 mm (minimum clearance of 3 mm to the chainstays) |
Available lengths |
170 mm 172.5 mm 175 mm |
Chainrings |
Garbaruk Praxis Works |
Max. Rider weight |
120 kg (265 lb) |
