Carbon-Ti X-Hub Centerlock Hubset
$749.95
The Carbon-Ti X-Hub SP Centerlock Hubset combines the brand’s precision Italian machining with modern straight-pull geometry for an exceptionally lightweight, durable, and serviceable hub platform for high-performance disc-brake wheel builds.
The rear hub utilizes a 7075-T6 alloy shell, 4-pawl driver, and a 56-tooth engagement ring for rapid, consistent pickup. Bearing preload is managed through a tool-less external adjustment ring on both hubs, allowing immediate fine-tuning during wheel service.
The front hub (92g) is available in 12 × 100 or 15 × 100 options; the rear hub (approx. 189g) is 12 × 142 with multiple freehub options including Shimano / SRAM 11-speed, SRAM XDR, Campagnolo N3W and Shimano MicroSpline.
This hubset provides optimized flange geometry, a centerlock disc interface, and straight-pull spoke holes — ideal for stiffness-focused, weight-conscious wheel builders across road, gravel, and cyclocross disciplines.
  FRONT REAR
 Weight ~92g ~189g
 Spoke Holes 24h
 Axle Standard 12 / 15 x 100 mm 12 x 142 mm
 Bearing Size 6903 - (1) / 6803 - (1)
 Brake Interface Centerlock
--Wheel Building Dimensions--
  LEFT RIGHT LEFT RIGHT
 Flange Diameter 48 mm 43.5 mm 48 mm 54.5 mm
 Center to Flange 33 mm 22.5 mm 36 mm 18 mm
 Spoke Hole Offset 2.0 mm
 Spoke Hole Diameter 2.5 mm
 Material 7075-T6 Aluminum
