ENVE Valve Core Remover
ENVE's valve core removal tool is a precision-machined accessory that simplifies tubeless tire setup and maintenance. Made from durable aluminum alloy, this compact tool has two ends: one for removing Presta valve cores to add sealant or replace damaged cores, and the other for threading onto the valve stem to protect the core. Included with ENVE's tubeless valve sets, it also serves as a high-performance Presta valve cap. Measuring 20mm in length and 5mm in diameter, this tool is essential for any cyclist's toolbox, streamlining setup and maintenance with its thoughtful design.
