Extralite BlackLock Front Thru Axle
Article number: | 11-03-03 |
SALE - 25% off (15.1 & 15.5)
With the rising popularity of thru axle designs being used by nearly every major fork and frame manufacturer, companies like Extralite have immediately filled in the niche for quality performance tuned parts that many discerning cyclists desire. With this in mind, Extralite has produced the Black Lock, a surprisingly lightweight thru axle skewer. Utilizing a unique externally tapered surface and precise dimensioning, Extralite is capable of shaving as many grams as possible while still maintaining a sturdy design that’s tough enough to withstand the abuse of a typical mountain bike ride. To ensure proper installation that’s as smooth as possible, each Black Lock comes with a self lubricating brass washer that is designed to reduce friction between the skewer and frame/fork.
Ordering
The Extralite Black Lock is available in configurations to fit most modern forks.
Each Black Lock thru axle is installed using a 6 mm allen wrench at a torque rating of 10 Nm. The tool fitting is located on the threaded side of the axle. It is highly recommended that threads are greased prior to installation to ensure a proper torque rating.
Model | Hub Compatibility | Interface | Length | Thread Pitch | Thread Length | Weight |
BlackLock 12.5 | TA 12 x 100 | Flat | 120mm | 12 x 1.5 mm | 12.5 mm | 20g |
BlackLock 12.5A | TA 12 x 100 | Flat | 116mm | 12 x 1.5 mm | 12.5 mm | 19g |
BlackLock 12.5B | TA 12 x 100 | Flat | 125mm | 12 x 1.5 mm | 14 mm | 21g |
BlackLock 15.1 | TA 15 x 100 | Flat | 143mm | 15 x 1.5 mm | 8.7 mm | 25g |
BlackLock 15.2 | TA 15 x 100 | Flat | 143mm | 15 x 1.5 mm | 16.2 mm | 27g |
BlackLock 15.3 | TA 15 x 100 | Flat | 146mm | 14 x 1.5 mm | 14.2 mm | 27g |
BlackLock 15.3B | TA 15 x 110 Boost | Flat | 156mm | 14 x 1.5 mm | 14.2 mm | 28g |
BlackLock 15.4 | TA 15 x 100 | Flat | 147mm | 15 x 1.5 mm | 12.2 mm | 27g |
BlackLock 15.4B | TA 15 x 110 Boost | Flat | 156mm | 15 x 1.5 mm | 12.2 mm | 29g |
BlackLock 15.5 | TA 15 x 100 | Tapered | 139mm | 15 x 1.0 mm | 11 mm | 27g |
Material | 7075 T6 Aluminum | |||||
Tool Fitting | 6 mm Allen | |||||
Recommended Torque | 10Nm |
15.4 (147mm)
- Rock Shox
- SID
- SL
- Ultimate, Brain , Select +, Select (2021)
- Ultimate (2021)
- Select / Select + (2021)
- WC, XX, RCT3, RLT, RL (2012-2015)
- SL
- RS-1 (2015-)
- Reba RLT, RL (2012-2015)
- Pike DJ, RC, RCT3 (2014-2015)
- Revelation WC, XX, RCT3, RLT, RL (2014-2015)
- SID
- Santa Cruz
- Stigmata
15.4B (156mm)
- Rock Shox
- SID RL, RLC, WC, Brain Boost (2016-2020)
- Reba RL Boost (2016-2020)
- Lyric RC, RC2, RCT3 Boost (2016-2020)
- NOT COMPATIBLE WITH THE 2021
- SID, SID SL (Ultimate, Brain Select=, and Select)
- RS-1
