Fair Wheel Bikes Shift / Brake Replacement Hoods
Article number: | 013-02-03 |
Fair Wheel Bikes introduces a new line of premium replacement hoods engineered for compatibility with today’s most common Shimano and SRAM road levers. Designed to match the tactile feel, fit, and durability of the originals, these hoods offer a reliable and cost-effective alternative to OEM options—all in a clean, black finish.
Each pair is precision-molded for a specific brake/shift lever model. Manufactured from durable, high-grip rubber, these hoods are ideal for riders seeking a no-fuss replacement solution that restores comfort and control without compromising aesthetics or performance.
For Force/Rival/Apex 10-speed mechanical levers
Fits 11-speed mechanical levers from Red22 and Force22 series
Compatible with R8000 series 11-speed mechanical levers
Designed for the original 10-speed Ultegra Di2 ST-6770 levers
For ST-6800 11-speed mechanical levers
Fits 11-speed Dura-Ace ST-R9100 mechanical levers
For ST-9001 11-speed levers (NOTE: not compatible with ST-9000)
Tailored for ST-9000 11-speed levers (NOTE: not compatible with ST-9001)
Designed for older ST-7900 10-speed levers
Meticulously designed for Campagnolo 11-speed EPS levers.
INSTALLATION INSTRUCTIONS
To ensure proper fit and durability, we recommend removing your levers from the handlebars prior to installation. This reduces the risk of tearing and allows for easier positioning.
To aid installation:
- Use a spray bottle of rubbing alcohol to lubricate the hood
- Dries tacky for a secure hold
- Alternatively, a mild soap solution or hairspray may be used
- Work quickly if using hairspray, as it dries fast.
Compatibility | Weight |
Dura-Ace 9100 | ~51g |
Dura-Ace 9001 | ~53g |
Dura-Ace 9000 | ~52.5g |
Dura-Ace 7900 | ~52.5g |
Ultegra 8000 | ~52.5g |
Ultegra 6800 | ~53g |
Ultegra 6770 | ~58.5g |
SRAM Red22 / Force22 | ~61.5g |
SRAM Red 10 Speed | ~58.5g |
Campy 11-Speed EPS | ~55g |
Material | Silicone Rubber |
