Fair Wheel Bikes Khamsin Titanium Stem
Article number: | 013-06-04 |
The Khamsin Ti stem is the sleeker (yet slightly heavier) brother of our Bajada stem. Unlike our other ti offering, this stem features one piece construction resulting in a smoother flowing aesthetic: no welds, and a more robust clampable portion for your handlebars.
TITANIUM BOLT UPGRADE: Run it as is, or pair it with black, blue, gold, or rainbow titanium hardware for increased weight savings and a uniform aesthetic. Follow the link here and select the color you want from the drop down menu and add to cart.
Length | 90 mm | 100 mm | 110 mm | 120 mm |
Weight | ~ | ~150g | ~ | ~ |
Stem Angle | ± 7° | |||
Stack | 43 mm | |||
Clamp Diameter | 31.8 mm | |||
Steerer Diameter | 1 - 1/8" (1.125mm) | |||
Max Torque | 6Nm | |||
Recommended Use | Road / Cyclocross / Gravel | |||
Material | Stem | Hardware | ||
Titanium | Stainless Steel |
