$50.00
Article number: 010-04-02
Meticulously forged from 7050 T6 aluminum, the Kalloy Uno represents the ideal median between price and performance. With a weight comparable to much more expensive options, the Uno easily finds its place among even the most elite builds. By utilizing a CNC controlled variable thickness internal structure, Kalloy is able to refine the performance and weight characteristics of the Uno, enabling it to have an impressive stiffness-to-weight ratio. With a completely minimalist design featuring no logos, the Uno is the ideal choice for those looking to complete that stealth look for their next build.
TITANIUM BOLT UPGRADE: Run it as is, or pair it with black, blue, gold, or rainbow titanium hardware for increased weight savings and a uniform aesthetic. Follow the link here and select the color you want from the drop down menu and add to cart.
 Hardware Stainless Steel
 Handlebar Clamp ø 31.8mm
 Steerer Clamp ø 28.6mm
 Length Weight w/ steel bolts Weight w/ titanium bolts
 60mm 96 grams 87 grams
 70mm 98 grams 89 grams
 80mm 100 grams 91 grams
 90mm 102 grams 93 grams
 100mm 107 grams 98 grams
 110mm 110 grams 101 grams
 120mm 117 grams 108 grams
 130mm 129 grams 120 grams
