Far and Near Pulley Bolts for 11 Speed Campagnolo
Article number: | 16-04-04 |
Availability: | In stock (12) |
Use Far and Near's pulley bolts to add some flair to your 11 speed Campagnolo derailleur. Far and Near designed their bolts with a wide 12 mm head to spread clamping pressure across a larger section of Campagnolo's carbon derailleur cage plates. These bolts are manufactured from light and strong 7075 aluminum, and are available in six bright anodized colors.
A T25 torx wrench is required to install Far and Near pulley bolts. If a torque wrench is available, we suggest tightening to 4 Nm. Each bolt features pre-treated threads to prevent accidental loosening.
*compatible only with pre-2011 derailleurs
Weight | 2.0 grams per pair |
Compatibility | 11 speed Super Record, Record, and Chorus |
Available Colors | black, blue, gold, green, red, silver |
