$150.00
Article number: 33-03-03
Feedback Sports unique single-arm truing stand is a professional-level, highly modular device with a price point that is competitive with "cheap" consumer truing stands. The Pro Truing Stand is compatible with most common bicycle wheels, with no need to remove the tire. It will fit wheel diameters up to 29", and is adaptable for quick release, 12mm, and 15mm axle standards. The precision screw indicator arm slides easily up and down the arm of the truing stand to adjust for wheel diameter, and is equipped with a spring-loaded tip for truing wheels laterally and radially. As an added feature, the indicator is equipped with a rotor truing slot. This stand is light and portable - it is designed to stand alone, or it can be removed from its base to be mounted to a Feedback repair stand or directly to a bench top.
Base Dimensions 10.25 x 8.5" (26.5 x 21.5 mm)
Height 20" (51 cm)
Weight 7.25 lbs (3.3 kg)
Portable Weight 1.4 lbs (.64 kg)
