$229.88
Article number: FitWorks
The PN, Performance Narrow, saddles offer a narrow chassis, ranging from 110 - 125mm wide, allowing superb thigh and hamstring clearance and greater rider body movement around the seat.
Like all ISM saddles, the PN series is nose-less and designed to remove pressure from soft tissue, ensuring maximum blood flow, no genital numbness, and a healthier, more enjoyable ride.
Model Length Width Rails Padding Usage
1.0 275 mm 110 mm Stainless 25-Series Foam & Gel Road, Triathlon, Time Trial
1.1 275 mm 110 mm Steel 40-Series Foam & Gel Road, Triathlon, Time Trial
3.0 255 mm 120 mm Stainless 30-Series Foam *Road, Time Trial*
3.1 255 mm 120 mm Chromoly 40-Series Foam *Gravel, Road, Time Trial*
4.0 255 mm 125 mm Stainless 30-Series Foam *Gravel, Road, Time Trial*
4.1 255 mm 125 mm Chromoly 40-Series Foam *Gravel, Road*
*This saddle is not recommended for cyclists who ride with a high seat position or those who ride very forward on the extreme front of the saddle
