$40.00
* Unit price: $40.00 /
Article number: 022-01-02
Precision machined from 7075 aluminum and vibrantly anodized, KCNC’s Low Profile 12x142mm Thru Axle is an exceptionally light upgrade option. Significantly lighter than OEM and rival companies equivalent options, these axles feature a low profile head that virtually eliminates the hang-ups on rocks and shrubs. For a sleek profile and lightest possible build these thru axles are the perfect choice. Available in KCNC’s signature colors to match any build theses axles offer a simple, functional, and beautiful option for those looking to upgrade.
Compatibility
KCNC’s thru axles come in several different threading and length options. Please make sure to select the correct axle type to go with your frame. For tool free installation check out KCNC’s Indexing and Quick Release thru axle options.
For complete sizing details on all of our thru axles please look HERE or give us a call.
E-Thru Interface Length Thread Pitch Weight
 161 mm Flat 161 mm 18 mm 12 x 1.5 mm ~27g
 171 mm Flat 171 mm 18 mm 12 x 1.5 mm ~28g
 Boost 167 mm* Flat 167 mm 18 mm 12 x 1.5 mm ~29g
 Boost 177 mm* Flat 177 mm 18 mm 12 x 1.5 mm ~28g
Maxle
 173 mm Flat 173 mm 21 mm 12 x 1.75 mm ~29g
 180 mm* Flat 180 mm 21 mm 12 x 1.75 mm ~29g
Syntace X-12
 163 mm Tapered 163 mm 18 mm 12 x 1.0 mm ~28g
 Recommended Torque 10Nm
 Material 7075 T6 Aluminum
 Tool Fitting 6 mm Hex
 Hub Compatibility T/A 12 x 142  |  T/A 12 x 148*
