$15.00
Article number: 023-01-06
KCNC's EVA foam grips provide a semi-ergonomic, lightweight perch for your hands. They are sold in pairs and are supplied with plastic bar plugs. KCNC grips are compatible with any 22 mm end-diameter mountain handlebar.
KCNC grips will fit tightly onto your handlebars, which can make installation difficult. We recommend lubricating the inner surface of the grips with isopropyl alcohol or hair spray. Once the grip is properly positioned, the alcohol will quickly evaporate, leaving the grip tightly secured on the handlebar.
 Weight ~22.5g
 Grips ~16.5g(per pair)
 Bar End Plugs ~6g (per pair)
