Redshift Shockstop Stem
$199.95
The ShockStop Stem offers a sleek suspension solution for road, gravel, and e-bikes. Made from 6061-T6 aluminum, it features an adjustable elastomer system for up to 20mm of travel. Available in 80-120mm lengths and weighing 256-302g, it comes in +/-6° and +30° options, with the oversized 1-1/4" steerer available only in the +/-6° configuration. Five elastomers allow fine-tuning for different terrains. Paired with the ShockStop Suspension Seatpost, it enhances control and comfort without sacrificing handling. Ideal for long rides, technical trails, or daily commutes, it’s a smart upgrade for any bike.
  • Unwanted vertical movement is absorbed by twin interchangeable elastomers
  • Stem retains torsional rigidity
  • Effective suspension travel: - Up to 20mm
  • Includes 5 swappable elastomers (2 pre-installed, 3 additional) to customize the ride feel for your bike, weight, and riding style
  80 mm 90 mm 100 mm 110 mm 120 mm
 Weight ~256g ~266g ~278g ~290g ~302g
Stem Angle
 +/- 6° +/- 6° / +30° +/- 6° +/- 6° / +30° +/- 6° +/- 6°
 +30° +/- 6° / +30° N / A +/- 6° / +30° N / A N / A
 Clamp Diameter 31.8 mm
 Steerer Clamp Diameter 1-1/8" (28.6 mm)  |  *1-1/4 (31.8mm)
 Stack Height 40 mm
 Material 6061-T6 Aluminum
 Rider Weight Limit 135 kg (300 lbs.)
1 - 1/4" ONLY comes in +/- 6°
