Sapim Laser J-Bend Spokes
| Article number: | Spokes |
Sapim Laser J-Bend spokes are an ultralight double-butted option built for performance-focused wheel builds where reducing rotational weight matters. The 2.0 - 1.5 - 2.0 mm profile removes material from the center section while maintaining strength at high-stress points.
Manufactured using Sapim’s cold forging process, Laser spokes offer excellent fatigue resistance and long-term reliability in lightweight road and gravel applications.
- Ultralight double-butted 2.0 - 1.5 - 2.0mm construction
- Reduced rotational weight for improved acceleration and climbing
- High fatigue resistance from cold-forged stainless steel
- J-Bend design for traditional hub compatibility
- Ideal for lightweight road and gravel builds
- Cost-effective alternative to bladed spokes
Sapim Laser is best suited for lightweight builds where minimizing rotational mass is the priority.
Ideal for climbing wheels, performance road setups, and lightweight gravel builds.
For more durability, choose Sapim Race. For aerodynamic performance, upgrade to Sapim CX-Ray.
Wheelbuilding Notes
The thinner center section increases elasticity, helping the spoke absorb load and maintain tension. This improves fatigue life while reducing weight.
Best suited for lighter riders or builds where stiffness is not the primary requirement.
Need help calculating spoke length? Use the Spoke Length Calculator, or contact our wheel builders.
| Specifications | |
| Weight | ~4.6 - 5.2 g |
| Material | Cold Forged Stainless Steel |
| Head Type | J-Bend |
| Profile | 2.0 - 1.5 - 2.0 mm |
| Thread | 2.2 x 56 tpi (2.0 mm x 14G) |
Custom Spoke Cutting Available
We can cut spokes to order when stock is available within 20 mm of the required length.
For exact lengths or custom builds, contact our wheel builders.
