Specialized Turbo Pro Tire
$50.00
Article number: 006-06-03
Specialized Turbo Pro Tire is a durable, performance-oriented clincher road tire that brings much of the speed and handling of the S-Works version into a more robust, everyday-ready package. Built with a GRIPTON® compound, BlackBelt puncture protection, and a 60 TPI casing, it delivers a balance of efficiency, durability, and consistent traction.
Compared to the S-Works Turbo, the Turbo Pro prioritizes longevity and flat resistance while maintaining low rolling resistance and predictable cornering. It is well suited to riders who want a fast road tire that can handle higher mileage, rougher pavement, and regular training use.
  • Daily road riding and high-mileage training
  • Riders prioritizing durability over absolute weight savings
  • Performance road bikes used for mixed conditions
  • Replacing worn race tires with a longer-lasting option
  • Pairing with durable road wheelsets
Key Features
  • GRIPTON® compound for efficient rolling and confident grip
  • BlackBelt protection improves puncture resistance for real-world riding
  • 60 TPI casing adds durability and structure compared to higher TPI race tires
  • Foldable clincher construction for reduced weight and easy installation
  • Available in 700x24, 700x26, and 700x28 sizes
Installation Notes
This is a clincher (tube-type) tire and should be installed with a compatible inner tube. Check rim tape condition, seat beads evenly, and inflate within the recommended pressure range based on rider weight and road conditions.
 Compound GRIPTON®
 Flat Protection BlackBelt
 Casing 60 TPI
 Bead Foldable Clincher
Size, Weight & Recommended Pressure
Size Weight Recommended Pressure
 700x24 ~200g 100–125 PSI
 700x26 ~220g 100–125 PSI
 700x28 ~240g 85–95 PSI
Pairs Well With
Pairing a durable performance tire with quality wheels and tubes improves consistency, reliability, and long-term ride performance.
