$95.00
Article number: 001-04-01
Designed specifically for road, gravel, and endurance applications, the SRAM Centerline XR (X Road) rotor blends weight savings, aerodynamic performance, and consistent braking in a durable 2-piece package. Featuring an aluminum spider and a stainless steel braking surface, the XR rotor prioritizes quiet operation and thermal stability—ideal for SRAM’s eTap AXS systems and beyond.
Heat Management & Durability
The Centerline XR rotor’s dual-material build offers excellent thermal dissipation under prolonged braking—critical during alpine descents and gravel rides. The aluminum spider minimizes heat transfer to the hub, while the steel braking track resists warping even after repeated heavy stops.
Rounded edges and a stiff carrier profile help maintain true rotor shape under extreme temperatures, reducing rub and noise.
Features:
Lightweight, two-piece design
Rounded edges are UCI-compliant and allow for easier wheel installs
Recommended for road or gravel use
Excellent Heat dissipation
Specs
 Centerlock / 6-Bolt 140mm 160mm
 Weight ~109g ~133g
 Color Black / Silver
 Torque Centerlock 6-Bolt
  40Nm 6.2Nm (55lbs)
 Includes Rotor / Lockring Rotor / Bolts
Material
Rotor Lockring Bolts
Aluminum / Steel Aluminum Steel
*140mm Centerlock rotor does not include lockring
_____________________: _________________________
Material: • Rotor - Aluminum / Steel | Lockring - Aluminum | Rotor Bolts - Steel
Compatibility: • Centerlock / 6-Bolt
Rotor Thickness: • 1.85 mm
Includes: • 1 - Rotor and Lockring or Bolts
